How can I know if any row is been added to my stream? I want to trigger an event on stream entry.
I am having a stream (not a value stream) where data is coming from different things or sources. I want to know or I want to trigger an event when data are getting inserted into my stream means when the number of row is incrementing by 1. Is there any way to create a custom event to trigger this event? Or any other way to know the changes in my stream table?
Rajat
PaiChungAnswer
22-Sapphire I
Due to the asynchronous nature of Streams you don't have an event you can trigger off unfortunately (unlike datatables which does have events)
You will have to use a different method or approach if you need this, either capture ahead of time someone is entering, or check the stream based on a schedule or other event.
Remember that checking the stream upon entry may not work as it is an asynchronous process.
PaiChung22-Sapphire IAnswer
22-Sapphire I
Support
Hi @RajatBain
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
