How can I set "Start Type" within a "AddPropertyDefinition" call?
I have a Remote Thing and want to add its remote properties automatically via a subscription / service.
This works well so far - I go through the GetRemoteMetadata's propertyDefinition and can create a property with correct names, types, categories, thresholds etc.
In the AddPropertyDefinition service there is a parameter named remoteBindingAspects
I would suspect I can use it to define the remote binding aspects - as in the UI.
However, most of them have their own parameter, i.e. remotePropertyName, timeout, pushType, pushTreshold etc.
There no hint on where to set the Start Type.
It's a default of "Use Default Value" which I need to change to "Read Edge Value" when adding the property.
Any ideas or examples for the remoteBindingAspects JSON would be appreciated.
Michael
mneumannAnswer
var remoteBindingAspects = {
 "startType": "readEdgeValue"
me.AddPropertyDefinition({
 remoteBindingAspects: remoteBindingAspects /* JSON */,
I browsed through the RemotePropertyDefinitions of properties I've already changed.
This allowed me to use above value to manipulate the aspects on adding a new property.
mneumann16-PearlAuthorAnswer
