How can we add keypress event in our textarea whenever a key is pressed in a textarea and a values is typed it should call a web service.
    posipovaAnswer
    20-Turquoise
    You may look into developing a custom java extension. Please see the documentation attached. Alternatively, you may reach out to your sales represenative to have you connected with the Global Services team  - they could develop the solution for you (for a fee).
    posipova20-TurquoiseAnswer
    20-Turquoise
    You need to create a custom widget which enables this feature. You can start from the default widget as a starting point or you can choose another one such as Google Widgets.
    Varathan
