How do I combine 3 edge clients, all with different attributes and make it look like one complex remote thing on the server side?
How do I combine 3 edge clients, all with different attributes and make it look like one complex remote thing on the server side?  Basically, The thing template on the server has 3 individual remote clients populating the instances (things) of the template.
I need one complex thing that is made of multiple individual remote things.
    Just create a another thing (Local Thing) based on the Template and bind the RemoteThings properties locally to the newly created merged thing.
    jwilson-21-VisitorAuthor
    Each of the remote things have their own template.  For instance TT_1, TT_2, and TT_3,  then 3 remote things Thing1, Thing2, Thing3.  I would like to have a Parent_Thing which is made up of all attributes and values that are Thing1, Thing2, and Thing3 but I don't believe I can have multiple inheritance there the Parent_ThingTemplate inherits all attributes from TT_1, TT_2, and TT_3.  Atleast with what I am aware of.
    You can map fields for TT_1, TT_2 and TT_3 on a ThingShape, then you will be able to inherit the "same" field names on the TT_1 and on the Parent_Thing.
    Then, as said, you can bind locally the TT_1.property1 to Parent_Thing.property1
    You can create data change subscriptions on all of your clients data and push it to a parent on "data change". You will need to set up the parent template or thing manually though, since there are different templates involved.
