how do i get a table that i created in postgre to thingworx?
i want to transfer the table created in postgre to thingworx composer, can you pls tell me the procedure for it.
Hi Swetha, are you using PostgreSQL as your ThingWorx's Persistence Provider or are you connecting to it via the JDBC connector/RDBMS connector? Also could you please elaborate a bit on your use case, are you just looking to show some data in ThingWorx Composer via a Mashup with for e.g. a grid widget? That won't require you to transfer data, you will be able to show this data in the mashup just via the SQL services.
Hi Sushant , i wana display my database values in my mashup, so i need procedure for that . Also is there any proper demo video for understanding data storage in thingworx?
Swetha assuming this is an external database, you can configure the Relational Databases Connectors ​or JDBC Connector Extension ​to connect to the database and query the table, you can download these extensions to ThingWorx from the ThingWorx Marketplace. Both of these extensions include the setup guide.
Additional reading :
Accelerate analytics and transactions on external data store for ThingWorx using Oracle 12c In Memory Column Store featu…
Types of JDBC Calls from JDBC Extension & RDBMS Extension in ThingWorx
