7-Bedrock
How do I get field comments in sqlserver tables
hi ,as the title ,How do I get field comments in sqlserver tables
and I tried the method in the picture but it didn't work
Support
Hi @chenzhuang111
Have you verified you can connect to the db from ThingWorx?  Does the db user have access to the table you're trying to access?   Are you able to run any query?  Try this one:
select @@version
You should also check to validate the db user account isn't locked.
--Sharon
