Oct 31, 2025 2:39 PM UTC
How do I know if an IMAGE property has a value?
How can I check from JavaScript whether the content of an image property has a value or the default value 'image not available'?
BR
Dimitri
nmutterAnswer
Oct 31, 2025 6:19 PM UTC
Try like this
let hasImage = me.imageProperty.length !== 0;
If no image is set the length should be 0
nmutter17-PeridotAnswer
Try like this
dbologna13-AquamarineAuthor
Nov 4, 2025 9:48 AM UTC
HI All,
The solution proposed by mmutter works perfectly.
Many Thanks
BR
Dimitri
Jamal Ashraf
Nov 3, 2025 5:45 AM UTC
I would check if an IMAGE property has a valid value is to ensure it’s both defined and not empty. You can use something like this:
let hasImage = me.imageProperty && me.imageProperty.trim().length > 0 && me.imageProperty !== "image not available";
This covers:
  • the property being undefined or null,
  • empty strings, and
  • default placeholders like "image not available".
I dont think that there is a default value 'image not available'. you would get 0 length if an image is not set.
If you’re using this check in a mashup or service logic, it ensures the image field is actually populated with a valid URL or base64 image data before you proceed.
Support
Nov 3, 2025 7:45 PM UTC
Hi @dbologna,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to support.
Abhi
