How do I remove datashape field from below JSON output?
"data": [
"usageId": "50030540014333322800000050",
"assetFound": true,
"compartments": {
"rows": [
"compartmentId": "50030540014333322800000052",
"observableProperties": {
"gatewayLocationDescription": "Ireland",
"temperature": 6,
"timestamp": 1612393200000
"compartmentUsage": {
"compartmentState": "Inuse",
"minTemperatureThreshold": 2.2
"compartmentId": "50030540014333322800000051",
"gatewayLocationDescription": "Belgium",
"temperature": 2,
"timestamp": 1612220400000
"compartmentState": "Idle"
"dataShape": {
"fieldDefinitions": {
"compartmentId": {
"name": "compartmentId",
"aspects": {
"isPrimaryKey": false
"description": "",
"baseType": "STRING",
"ordinal": 1
"name": "observableProperties",
"aspects": {
"description": "",
"baseType": "JSON",
"ordinal": 3
"name": "compartmentUsage",
"aspects": {
"description": "",
"baseType": "JSON",
"ordinal": 2
"message": "Information found",
"status": "Success"
Hi @KN_9774047
You can refer to below link to get rid of datashape fields coming along in your JSON output:
Remove DataShapes from JSON Output
Do revert for more queries.
Sudeepta
Tried that way in Thingworx 9.0.3 but not working out.
datShape field is still showing up in the output
Hi @KN_9774047
I gave the code a try in 9.0.3 and able to get output without datashape. Sharing my script for reference:
Spoiler
var params = {
infoTableName: undefined /* STRING */,
dataShapeName: "DS" /* DATASHAPENAME */
// result: INFOTABLE
var result1= Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var newEntry = new Object();
newEntry.name = "test1"; // STRING - isPrimaryKey = true
newEntry.value = "test 1"; // STRING - isPrimaryKey = true
result1.AddRow(newEntry);
newEntry.name = "test2"; // STRING - isPrimaryKey = true
newEntry.value = "test 2"; // STRING - isPrimaryKey = true
newEntry.name = "test3"; // STRING - isPrimaryKey = true
newEntry.value = "test 3"; // STRING - isPrimaryKey = true
var param = {
table: result1 /* INFOTABLE */
var result = Resources["InfoTableFunctions"].ToJSON(param);
result.array = result.rows;
delete result.rows;
delete result.dataShape;
Spoiler
JSON Output:
"array": [
"name": "test1",
"value": "test 1"
"name": "test2",
"value": "test 2"
"name": "test3",
"value": "test 3"
Could you attach your service code here if still not getting output without DataShape.
