How I can show selected properties in a Line Chart Widget (Mashup)
I'm getting all properties from a Thing in a mashup.
How I can get rid of one of them (FaultCode for example)?
jenscAnswer
One way you could do this would be to create your own service and filter out your data in there.
Jens
jensc17-PeridotAnswer
Jens
I have accomplished following your suggestion and works,,,, but I suspect that should be a shorter way.......
var modelProperties = Resources['InfoTableFunctions'].CreateInfoTable({infoTavleName: "modelProperties"});
modelProperties.AddField({name: "name", baseType: "STRING"});
modelProperties.AddField({name: "description", baseType: "STRING"});
modelProperties.AddRow({name: "PreheatTemperature"});
var data = me.QueryNamedPropertyHistory({
    propertyNames: modelProperties,
    maxItems: 1000
result = data.ToJSON();
or this one:
let data = me.QueryNumberPropertyHistory({
"propertyName": "PreheatTemperature"
data.RemoveField("id");
I haven't really used these "QueryNamedPropertyHistory" and"QueryNumberPropertyHistory" services.
But if the services work, then that should be fine!
Jens
