Jun 11, 2020 11:57 AM UTC
How i use vertical divider in mashup?
I want to use vertical divider in mashup
cmorfinAnswer
Jun 11, 2020 1:27 PM UTC
Hi @Ru_01
Following Custom CSS should allow to make the divider vertical
.widget-ptc1divider::part(line){
transform: rotate(90deg) !important;
See also https://www.ptc.com/en/support/article/CS323038, in release 9.0, the divider widget as a flag to make it vertical.
Hope this helps
Christophe
Support
Jun 11, 2020 1:16 PM UTC
Hi @Ru_01.
Are you saying you want to add a vertical divider?  What version of ThingWorx are you running?
Please provide more information so we can assist.
--Sharon
Ru_0114-AlexandriteAuthor
Jun 12, 2020 5:52 AM UTC
I am using 30 days free trial
cmorfin19-TanzaniteAnswer
Hi @Ru_01
Hope this helps
Christophe
