How old data is being retained by services QueryAlertSummary and QueryAlertHistory from current date
Explain the difference between these two services.
Thanks in advance
slangleyAnswer
Support
Hi @ranjank.
When running the services in Composer, the number of records returned is limited to 500.  If you need to pull more, then you need to design a mashup to display the data.  This will allow you to pull ALL data if needed regardless of timeframe.
--Sharon
18-Opal
In short, the difference between the two is that QueryAlertHistory uses AlertHistoryStream, while QueryAlertSummary doesn't.
/ Constantine
ranjank1-VisitorAuthor
Could you pls let me know how much data is being retrieved by QueryAlertSummary and QueryAlertHistory with respect to current time?
18-Opal
That's defined by service parameters -- both maximum number of items, as well as start/end timestamps.
/ Constantine
