How to access what was selected in Collection widget
Hello everyone,
I have a service that returns an infotable with a column that contains multiple rows with infotables.
I want to use a collection widget to display the nested infotables dynamically (depending on how many rows there are).
The user is supposed to select something in one of the infotables. This selection, I want to use!
This were the bindings I created. But in the label which should display the selection data, nothing is displayed. Is this a bug or am I doing something wrong?
Note: please disregard [object object], I have set DisplayField, StateField, ValueField but for privacy reasons I took the screenshot before I set it.
I would appreciate any help!
Thank you!
@HD_10225728 : To the label, can you please try binding the SelectedText property of the list?
Thank you for your help! Sorry, I described it maybe not right.
I want to pass back what was selected in the static collection mashup, to the "main" mashup that contains the collection widget.
MashupGlobalPropertyBinding property of Collection widget can be used to achieve above mentioned functionality.
Reference Link
Hope this Helps!!
