11-Garnet
How to add an image from a repository to a table?
Hello,everyone!
Why does it fail when I use the AddDataTableEntry service to add an image from a repository to a table?
  • Create one more field with "IMAGE" basetype
  • Use GetImage() to get the image from respository  and insert into infotable
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(test_grid_image)
let image_data = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape({
 infoTableName: "InfoTable",
 dataShapeName: "test_grid_image"
// result: INFOTABLE dataShape: "FileSystemFileWithLinks"
var fileList = Things["SystemRepository"].GetFileListingWithLinks({
	path: undefined /* STRING */,
	nameMask: undefined /* STRING */
var fileCount = fileList.length;
var f = 0;
for( ; f < fileCount; f++){
 let newEntry = {
 path: undefined, // STRING [Primary Key]
 size: undefined, // NUMBER
 downloadLink: undefined, // HYPERLINK
 lastModifiedDate: undefined, // DATETIME
 name: undefined, // STRING
 img: Things["SystemRepository"].LoadImage({
 path: "/image.png" /* Replace with youe actual image paths*/
 }) // IMAGE
 image_data.AddRow(newEntry);
result = image_data;
It worked for me.
Rocko
Hard to tell with the information given. Check the logs. Maybe the user lacks access/service execute privileges to access the file.
Maybe it does not get added to the DataTable. Maybe it's not queried correctly. Maybe the type is wrong.
Check if the link is contained in the datatable. Check the link is contained in the infotable you use as data source in the grid.
Snoopy_hu11-GarnetAuthor
11-Garnet
Ok thanks, I'll check the logs afterward!
pshashipreetham
hi @Snoopy_hu ,
In Column format of the colum "cImageLink" what did you give it?, it should ImageLink type
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
11-Garnet
Yes, I chose the imagelink type.
var f = 0;
 let newEntry = {
 }) // IMAGE
It worked for me.
11-Garnet
Ok thanks, I'll give it a try as soon as possible
