How to add default suffix to entity name?
I want to give entity name as TreeThing_abc where _abc is the suffix. Whenever I want to give the name for any entity, _abc should come by default and then I'll add the prefix name based on the entity that I create. Is there any possibility to get default name for entity name.
thanks
sameera
You just need to use CreateThing snipped and add the desired sufix:
var sufix = "_mySufix";
Resources["EntityServices"].CreateThing({
 description: "",
  thingTemplateName: "GenericThing",
  tags: undefined
Not with the Composer, but you can create a custom service in order to create entities and in this service add the suffix by the rules you desire, it's how we do it.
Thanks @CarlesColl,
Is there any snippet to add suffix for entity name.
sameera
 description: "",
  tags: undefined
