How to add json data to an infotable
I'm currently using the following lines to create an infotable from json:
	var json = {
		rows: jsonData.run_history, //an array of objects
		dataShape: DataShapes["SomeDataShape"].GetDataShapeMetadataAsJSON()
	//Loads json data to an infotable
	var data = Resources["InfoTableFunctions"].FromJSON({
		json: json
I'd like to add more data from jsons to the infotable, but the FromJSON service replaces the previous data.  Is there a service that adds JSON data to the infotable?  Kind of like .AddRow?  I'd like to avoid using a for loop to add each row one-by-one as there are many rows.  Also, is there a limit to the size (MBs) of the infotable?
VelkumarAnswer
Hi @Willie
If you want to merge two infotable with same datashape, use the Union function
let params = {
 t1: infotable1/* INFOTABLE */,
 t2: infotable2/* INFOTABLE */
// result: INFOTABLE
let result = Resources["InfoTableFunctions"].Union(params);
For different datashape please refer to his article - Article - CS237109 - How to Merge InfoTables in ThingWorx (ptc.com)
I don't think InfoTable has any size limitation based on my experience.
/VR
Velkumar19-TanzaniteAnswer
Hi @Willie
let params = {
/VR
Willie16-PearlAuthor
Hi @Velkumar
I forgot about that one.  Thank you.
Regarding the size of the infotable, I should have said the amount of memory used in a service.  In AWS Lambda, it can error if the the amount of memory used in the lambda function exceeds the amount of memory set for the lambda function.
Hi @Willie
I really don't have any idea about InfoTable Sizing for Lambda function.
Please create PTC support ticket for this requirement
/VR
