How to add property values of a thing to infotable in ThingWorx
I want to add property values of a thing to an infotable/datatable thing in ThingWorx,
For Eg: I have a datatable with a datashape having three columns(column 1, column 2, column 3)
also, I have 3 properties (column1Prop, column2Prop, column3Prop)
I want to add these properties as a Row to the datatable.
Can anyone help me please.
Thanks in advance.
Aditya Gupta
Rocko
RockoAnswer
Hi Aditya,
you would create a subscription to a DataChangeEvent that fires whenever one of those properties was changed.
in that subscription you would add a row to the dataTable. Roughly like this:
let v=DataShapes["TheDataShapeOfYourDataTable"].CreateValues();
v.AddRow({prop1:eventData.newValue.prop1, prop2:eventData.newValue.prop2, prop3:eventData.newValue.prop3);
me.AddDataTableEntry({values: v});
The question is though why you would not use Value Streams instead which are explicitly made for that use case. Just assign a value stream to the thing and set the three properties to "logged".
Hi, @Aditya1702  Take a look at the below reference article.
https://www.ptc.com/en/support/article/CS277418
Hi @Surya_Tiwari ,
I am not able to understand this, I will just brief you once again what I want to achieve:
I have few properties which are changing, so everytime the value changes I want to add those property values into a datatable.
eg. I have property1, property2 & property3 so evertyime the value of these properties changes I want to record them into a datatable.
Do you have any solution for this?.
Thank You.
Aditya Gupta
Rocko
Rocko19-TanzaniteAnswer
Hi Aditya,
