how to add warning alert on dashboard?
hello friends, I'm users of the free Thingworx platform
I would like to know how I inform the user when one of the variables is irregular, for example:
production = 0 "production stopped"
thanks in advance.
cmorfinAnswer
Hi @Marcus_Konflanz
I have attached a mashup that uses all the different functions as example.
For your case, look at how the bottom field "Enter  text in upper case" is made.
A validator check that the text is in upper case (in your case that will be the value 0 for example) and then the output is sent to some status message functions.
Hope this helps
Christophe
Hi @Marcus_Konflanz
You can use a validator function to check the value and bind the true/false event to a Status Message function.
Hope this helps
Christophe
hello @cmorfin , thank you for your time
I didn't quite understand how to validate and associate the message, could you explain it to me?
cmorfin19-TanzaniteAnswer
Hi @Marcus_Konflanz
Hope this helps
Christophe
