How to assign the Image to Image widget
I want to assign the Image to Image Widget. How to achieve.
Image is available in the SystemRepository
In Below service,I am loading the image and return the Image type
var params = {
path: MyImagefullpath /* STRING */
var result = Things["SystemRepository"].LoadImage(params);  // Here result type is Image type
In Mashup , I am trying to bind the result value to Image Widget. It is not accepting.
Could you please advise how to assign the image(Image in SystemRepository) to Image Widget.
Thank You
cbuseAnswer
var imageName = "mediaEntityName";
var result = "";
if (MediaEntities[imageName]) {
  result = "Media entity already exists";
else {
  result = "Media entity does not exist";
The input for the Image widget needs to be of type IMAGELINK and it looks like this: /ThingWorx/MediaEntities/imageName
Use the image returned from LoadImage service as input for creating a media entity.
// create a media entity
var paramsCreateMediaEntity = {
  name: imageName /* STRING */,
  content: loadImageResult /* IMAGE */
Resources["EntityServices"].CreateMediaEntity(paramsCreateMediaEntity);
// output the source URL of the media entity which can be used as input for the image widget
var result = "/Thingworx/MediaEntities/" + imageName
vi116-PearlAuthor
Thank you for the solution. Its working for me.
How to check the condition if Media entity with same name available or not before creating media entity.
Thank you
cbuse13-AquamarineAnswer
var result = "";
else {
