How to bind SelectedViewQuery of with grid widget
Hi Everyone,
I came across this doubt like I have a data which is populating in Grid now I filter the data based on column selected row with the help of data filter widget and saved that view in list widget now my ask is when I click on that view name then that particular view should reflect in Grid widget
I have a service called getViewField and which is having a result as selectedview in json format now how should bind it with the grid should I change the Json type or something else
I directly bind it with query filter but that is not working
so suggest me proper binding
Lav.
Hello @LY_10691079 ,
can you try getting the result of your getViewField service into infotable and bind the infotable to grid based on your condition (like clicking on the list name you can call the service)
Let me know if it works for you or you have any other queries.
