11-Garnet
How to bring Tree type grid using collection widget
Hi Guys,
I have a req., to bring a dropdown inside tree advanced grid, since it became OOTB for dropdown inside grid, I moved to collection, then the struggle is to manage the tree structure.
Any suggestion please...
regards,
John
I hope your hierarchy has no more than two levels or the performance (and maintainability) will suffer.
Basically you will need a collection widget inside of a collection widget:
  • Collection Widget (Parent)
    • Either content or another collection widget
The mashup that represents each row, must evaluate a mashup parameter to either display the dropdown (or whatever you want to show) or another collection widget which has essentially the same setup as the parent. I think I would just use the "Contained Mashup" widget for this. In theory you can create as many layers as you want... but the data handling is no fun.
