7-Bedrock
January 18, 2017
How to call services from a thing and return JSON format through REST?
  • January 18, 2017
  • 3 replies
  • 3312 views
I created a thing with services that able to return a INFOTABLE.
I did tried to create another services that used .ToJSON() and return result in JSON base type.
Both way i couldn't get the result in JSON format when i use postman GET method.Untitled.jpg
REST return  Unexpected 'I' and i don't know what is this mean.
Can somebody tell me how to make it?
Thanks in advanced!
Best answer by ttielebein
Calling services via REST API are POSTs not GETs. You need to change the type to POST and provide a content-type (likely just application/json). Hope this helps!
Hi Ang CC​, Try running the service directly from the composer and check result. Also, make sure to set datashape of the infotable in the script itself.
Check Application logs/Script logs for any error(s).
I hope it helps.
Ankit Gupta
acc7-BedrockAuthor
7-Bedrock
January 19, 2017
Thanks Tori Tielebein​, POST is the correct way with the header content-type.
