How to center align the tabset
I would like to center align the tabset. I have also attached the image for reference.
Note: I inspected and added the below CSS it worked. But if I try writing in custom CSS then it didn't work. So I need the CSS to be added.
justify-content: center;
Not sure about CSS.
But we approached this use case with "Button Bar" and "Expression". And, its working fine.
I need that tab to be in the middle
try below code.. its working for me..
.widget-ptcstabset::part(tabs-header)::part(tabs) {
