How to change color scheme for Progress Gauge widget for various value ranges?
I am using Progress Gauge widget to show some data. My requirement is to change the color of Progress gauge widget when value changes, for example I want color "Red" for 0 to 30 , color "yellow" for 31 to 60 etc.
I am using ThingWorx 8.5.
Thank you.
cmorfinAnswer
Hi @Marcus_Konflanz
You should be able to achieve this using state formatting for ProgressFormatter attribute - you can also use the ValueFormatter if you want the color of the value follow the same colour scheme as the progress bar.
Regards
Christophe
cmorfin19-TanzaniteAnswer
Hi @Marcus_Konflanz
Regards
Christophe
hello @cmorfin @ thanks for your time and help.
however I don't know if I'm having configuration problems,
or if these tools are no longer available, as they are not a difficult encounter. anyway, I am grateful for your attention
Hi @Marcus_Konflanz
I am not sure if I understand well your last post. Are you saying you do not see the ProgressFormatter attribute in the Progress Gauge widget ?
I am using ThingWorx 8.5.4 with Progress Gauge 2.0.0 and I do have them.
Christophe
