How to change font type
Dear Team,
How to change font type? As in style there is no options for font changes.
Thanks in advance
    Hi Bhuwaneshwar, for which widget are you attempting to change the font?
    Not sure if you have already seen this extension called Font Labeling available for download from ThingWorx Marketplace
    bgupta-210-MarbleAuthor
    That extension are work for label only. I need for all widget level.
    As far as i know you will need to call a custom CSS style sheet to apply different font styles.
    Hi Sushant,
    Can you help me regarding this how to call custom css in thingworx.
    Do you want to change the font for the entire platform and all mashups/widgets? This is possible with an extension that includes the font you wish to use as an UNKNOWN resource type in the meta data, and including runtime CSS such as:
    @font-face {
      font-family: 'ITCBLKAD';
      src: url(ITCBLKAD.TTF);
      font-weight: normal;
      font-style: normal;
        font-family: 'ITCBLKAD', Arial, sans-serif !important;
    James
    Could you explain with more details or share the extension you mentioned.
    Hi James,
    I need for widget.
    HI All,
    Font Labeling Widget is available at ThingWorx IoT Marketplace  for this case.
    Thanks & Regards,
    Sathishkumar C
