How to change Grid Advanced widget text font to some external font
I have a new font that i want to set to rows text of my gridAdvanced widget,
"font-family": ["ZCOOL QingKe HuangYou", "cursive"]
I tried the css and grid configuration, may be somewhere i am getting wrong.
css is working for labels, but how shall i write css for grid rows font?
Can anyone please try this and help me set this font to my Grid Row Text?
In Thingworx composer I am using GridAdvanced widget.
in the screenshot below,
Left side is Grid-Advanced widget, & Right side Zeros(0) are label widgets.
I need the font of GridAdvaced Text ( 1       0 ) to be the same as label font.
For label I am using following css.
Please try it for grid advanced widget in thingworx, and let me know if anything works for it.
Thanks in advance.
This is solved by finding the widget class / ID from runtime mashup and applying the css to it directly once the font is imported as .css file in FileRepository.
for example , in my case I use the following css code:
@import("/Thingworx/FileRepositories/customcss/digitalclockfont.css");
#root_pagemashupcontainer-8_gridadvanced-96-grid-advanced .objbox table btody tr td {font family: 'Zcool Qingke HaungYou',cursive;}
and this code is pasted in "custom css" of that mashup.
& wohoo that worked .. !
Hello @Rocky_2021 ,
The following custom CSS seems to work fine, although it doesn't change the header font.
@supports (ptcs-style-unit: "PTCS-CORE-GRID") {
 [part~="cell-label"] {
 font-family: 'yourFontFamilyHere';
However I think this will target ALL grids, so be careful with how you use it.
To change the header font you might be able to use [part~="header-label"].
A good consideration is also that PTC does not recommend using custom CSS.
Jens
Rocky_202110-MarbleAuthorAnswer
