6-Contributor
Sep 7, 2018 7:21 PM UTC
How to change session timeout setting just for a single user?
I followed below steps:
Subsystems -> UserManagementSubsystem -> Configuration, there is a setting called 'Idle Session Timeout'. The default value is 30 minutes. Set it to desired time > Restart Tomcat .
but this change the session timeout for all the users, I am only looking to change it for a single user.
Sep 10, 2018 7:41 AM UTC
You can have a custom user property setting with the timeout and another property with last operation (that you will need to update each time the user interacts with the server), and a timer that every minute (for instance) checks for logged in users (GetActiveUsers), and for those which are logged check the timeout setting and execute TerminateUserSessions accordingly.
Support
Sep 7, 2018 8:19 PM UTC
Hi @njain-31.
There currently is no mechanism for setting the session timeout for selected users.  It's a global setting.
--Sharon
If my response has answered your question, please mark as Accepted Solution, for the benefit of others who may have the same question.
njain-316-ContributorAuthor
6-Contributor
Sep 7, 2018 10:39 PM UTC
Can you assist me with possible ways to keep User logged in session alive for log time.
Will external application like auto click on web page can work?
