How to change the date-time display format universally across the application on ThingWorx 7.3 ?
  • March 16, 2017
  • 2485 views
We migrated from ThingWorx 5.4 to 7.3. After that all the date picket date-time format changed. we need to go to each Widget across different mashups and change the display format. Is there an easier way to globally change the format of display across the application.
Hi Ananthakrishnan, date time format could be changed globally using the Localization Tokens, the one defined in the Default localization table, so navigate to System > Localization Tables > Default > dateTimeFormat_Default   .... and change the format here
Hi Ananthakrishnan Ramu​,
Sushant above is right, and - moreover - using other Localization Tables you can set the date time format to be different in different languages. There is a bunch of different tokens related to dateTime, just use dateTime* to find them all.
J.
