How to change the tooltip format on Line chart
Hi team,
I want to change the default tooltip format on the Line chart. We have a requirement where we are using the Line chart as a step chart on Thingworx 9.3 version. The default tooltip is "Wed Mar 02 2022 02:59:16 GMT +0530(India Standard Time), Signal:1", which I want to change to "2022-03-03 02:59:16, Signal:1". I came across the Localization tables in TW where you can customize the tooltip. By following this link https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Mashup_Builder/Widgets/CreatingCustomChartTooltips.html
I created a new token, now I am getting "Signal:1" on the tooltip, but I am not able to understand how I can customize the Timestamp. The default token is "${label}, ${series}: ${value}".
Thank you!!
slangleyAnswer
Support
Hi @MM_9023322.
The release of ThingWorx 9.3.4 is now available on the PTC download site.  Hopefully, it will resolve your issue.
--Sharon
Support
Hi @MM_9023322.
You may have to change the way the data is stored in order for the tooltip to display per your requirement.
--Sharon
Support
Hi @MM_9023322.
Something else.....I assume you already have the XAxisType set to Date/Time.  If so, there is an XAsixDateFormatToken that may work but you will have to play around with it.
--Sharon
7-Bedrock
We want to change the datetime format on the hovering to only Date or remove the timezone from the tooltip . Please let me know if you have any input on this.
@slangley
Support
Hi @MM_9023322
We will be providing a fix for this in ThingWorx 9.3.4.  I don't yet have the release date, but it is estimated to be available in the next 2 - 3 months.
--Sharon
