How to check 'DoesThingExists' in TWX 9.1 using script
Hi Team,
I was using TWX 8.3 version earlier which was having below snippet:-
var params = {
thingName: thingName /* STRING */
// result: BOOLEAN
var result = Resources["PTC.Factory.CommonUtilities"].DoesThingExists(params);
But in ThingWorx 9.1, PTC.Factory.CommonUtilities is not available.
How would I run my code now?
Please provide snippet for ThingWorx 9.1 for checking the existence of Thing in the composer.
Thanks in advance.
slangleyAnswer
Support
Hi @ranjank.
PTC.Factory.CommonUtilities sounds like ThingWorx Apps.  Do you have Manufacturing or Service Apps installed?
As an alternative, you could do something like this:
try{​​
result = Things[thingName].name;
catch (err) {​​
result = "Thing does not exist";
You'll need to pass in the thingName you're looking for.
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @ranjank.
try{​​
catch (err) {​​
--Sharon
Support
Hi @ranjank.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
