How to check if mashup is opened as popup?
Hey,
im currently working on TWX  9.4.1-b313.
I was wondering, if there is a way to check if the current mashup is opened as popup/modal popup?
Thanks in advance
Markus
wcuiAnswer
Hi @Markus_Neini
I am afraid there is no such functionality for Mashup to tell if it is opened as popup or not.
But you can refer to below article, add a Mashup parameter and let caller set this parameter when opening mashup as popup.
https://www.ptc.com/en/support/article/CS401845
We are also interested in the reason of your request. Please share the background so we may find other possible workarounds. Thanks.
wcui16-PearlAnswer
Hi @Markus_Neini
I'm currently creating a mashup that can be opened as a new page or popup window. The mashup behaves differently depending on the window type. A back/close button should either close the window or return to a home page.
I'm currently working with a self-created mashup parameter "IsPopup" (Bool) and just wanted to find out whether there might be an official way to achieve this.
I did not find anything about it in my research. T _ T
Best regards
Markus
