How to clear or reset a Dropdown widget on a button click without reloading the mashup?
I am using Thingworx version 9.1.0. I want to reset or clear a dropdown value on a button click. I couldn't find any proper solution for this. If reload the mashup on that button click, the dropdown value will set to "Hint Text" property. But I do not want to reload the entire mashup.
suvermaAnswer
Hi @RajatBain
Thanks for reaching out to us on Community.
The feature you are seeking is already being worked upon as an enhancement and should be available in upcoming releases. I can notify you on this thread when the feature is available.
For time being, could you refer to this post: Dropdown reset on cancel button for a workaround, if that helps.
suverma14-AlexandriteAnswer
Hi @RajatBain
RajatBain1-VisitorAuthor
Hi @suverma ,
Thanks for your response. We developers will be really appreciated for that feature in upcoming releases.
As of now I am using a service to give empty string as result and binding that to selected text of the dropdown.
Thanks again.
@RajatBain ,
Please check the article https://www.ptc.com/en/support/article/CS337514
Hi @Jimwang ,
Thank you for your response. I will try this too.
Support
Hi @RajatBain.
If one of the previous responses helped you to find a solution, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
