How to combine infotables and their meta data
It seems that when I combine infotables with "union" their meta data do not get combined.  Is there a way to combine the meta data as well?  Meta data are fields such as source, timestamp, tags, location, etc.  The infotables are query results from a data table.  When I set the output of the service as "INFOTABLE" and "infotable type" to "is Data Table", I still do not get the meta data.
			let tableLength = someInfoT.rows.length;
			for (let x = 0; x < tableLength; x++) {
				let row = someInfoT.rows[x];
				//Your code here
				let query = {
					"filters": {
						"type": "And",
						"filters": [{
								"type": "EQ",
								"fieldName": "SomeID",
								"value": row.SomeID
								"type": "LT",
								"fieldName": "SomeDate",
								"value": oneYearAgo
				let queryResult = Things["SomeDataTable"].QueryDataTableEntries({
					maxItems: undefined /* NUMBER */ ,
					values: undefined /* INFOTABLE */ ,
					query: query /* QUERY */ ,
					source: undefined /* STRING */ ,
					tags: undefined /* TAGS */
				// result: INFOTABLE
				result = Resources["InfoTableFunctions"].Union({
					t1: result /* INFOTABLE */ ,
					t2: queryResult /* INFOTABLE */
Support
Hi @Willie.
Did you provide the full code snippet?  If so, it looks like you're missing one of the tables you're trying to join.
What version of ThingWorx are you running?
Regards
--Sharon
Willie16-PearlAuthor
Hi @slangley
No, I just included the pertinent lines as the service is a lot longer.
I wrote separate test services to see if infotable union includes meta data.  Based on my tests, it seems that it does if it is not in a for loop.  The output of the code below included meta data.
let query = {
 "filters":{
 "type": "EQ",
 "fieldName": "key",
 "value": 55
let infoT1 = Things["SomeDataTable"].QueryDataTableEntries({
	maxItems: undefined /* NUMBER */,
	values: undefined /* INFOTABLE */,
	query: query /* QUERY */,
	source: undefined /* STRING */,
query = {
 "filters":{
 "type": "EQ",
 "fieldName": "key",
 "value": 60
let infoT2 = Things["SomeDataTable"].QueryDataTableEntries({
var result = Resources["InfoTableFunctions"].Union({
	t1: infoT1 /* INFOTABLE */,
	t2: infoT2 /* INFOTABLE */
query = {
 "filters":{
 "type": "EQ",
 "fieldName": "key",
 "value": 70
let infoT3 = Things["SomeDataTable"].QueryDataTableEntries({
	t1: result /* INFOTABLE */,
	t2: infoT3 /* INFOTABLE */
However, I noticed that when the infotable union occurs in a for loop, it does not include meta data.  The output of the code below did not include meta data.
var result = DataShapes["DataTableB.DS"].CreateValues();
let oneYearAgo = new Date() - 31536000000;
let infoTA = Things["DataTableA"].GetDataTableEntries({
	maxItems: 20 /* NUMBER */
let tableLength = infoTA.rows.length;
	let row = infoTA.rows[x];
	//Your code here
	let query = {
		"filters": {
			"type": "And",
			"filters": [{
					"type": "EQ",
					"value": row.SomeID
					"type": "LT",
					"value": oneYearAgo
	let infoTB = Things["DataTableB"].QueryDataTableEntries({
		t2: infoTB /* INFOTABLE */
