Feb 7, 2022 5:19 PM UTC
How to configure SSL certificate programmatically
I have a config.json (it works fine) like
 "certificates": {
 "validate": true,
 "allow_self_signed": false,
 "cert_chain": [
 "/path2cert/entrust_l1k.pem",
 "/path2cert/entrust_g2.pem"
How could i write it in programming? Because ServerCertFileInfo property only allow me to specify one cert file
var client = new ConnectedThingClient(new ClientConfigurator
	AllowSelfSignedCertificates = false,
	DisableCertValidation = false,
	ServerCertFileInfo = new CertFileInfo { CertType = 0 /* TLS */, FilePath = @"/path2cert/entrust_g2.pem" },
Any help would be greatly appreciated
Hung Tran
Feb 7, 2022 9:32 PM UTC
Some helpful articles:
From "Help Center" - ".NET SDK: ClientConfigurator Class": http://support.ptc.com/help/edge_sdk_dotnet/r5.8.0/en/index.html#page/dotnet_sdk/c_dotnet_sdk_reference_clientconfigurator_class.html
Discussion earlier - "Client certificate authentication in Java": https://community.ptc.com/t5/ThingWorx-Developers/Client-certificate-authentication-in-Java/td-p/528567
htran-2115-MoonstoneAuthor
Feb 7, 2022 9:53 PM UTC
Thanks for your quick reply, however you misread my question, the Thingworx server is configured properly, it's already been working with config.json + wsems / localems. I just don't know how to setup cert chain for the ClientConfigurator object.
Hung Tran
Feb 8, 2022 11:24 AM UTC
Hello @htran-21 ,
pls check the following article to set up cert for CCO.
https://www.ptc.com/en/support/article/cs272670
Let me know if that helps.
Regards
Bhawna
