How to configure the mashup's resolution?
Hi all,
I'm starting in the plataform and I'm having some difficulte with mashup's resolution.
My question is:
How to configure the mashup to open with the same resolution in my devices (smartphone, notebook, tablet...)?
I am creating a mashup type responsive (advanced) and I had been tryed with the type just responsive too.
Hello leinsfeld,
Thank you for reaching out on the ThingWorx Developer Community.
In order to set a specific resolution/size for the mashup you will need to utilize a Static Mashup. Static Mashups allow for a fixed width and height to be set.
In order to set these to the desired values open the Static Mashup, choose Design and then select Explorer in the left pane. Select "Mashup" then scroll the available properties in the bottom left-hand box until you find Width and Height.
Hopefully this helps.
Tyler Misner
ThingWorx Technical Support Engineer
leinsfeld1-VisitorAuthor
Hello @tmisner
Thank you for your answer.
I did the following:
I have created a mashup (type: responsive advanced), but when I run the mashup in smartphones IOS the screen not to adjust automatic and when I run in smartphones Android the screen it is ok.
Have you ever been through for this problem?
Follow below the images:
AndroidAndroidIOSIOS
