How to connect Mosquitto MQTT server to Thingworx MQTT client
Hi Team,
I have installed mosquitto server in my windows system and my thingworx is installed on AWS  instance.I have started mosquitto server from my windows and then configure the thingworx MQTT thing with my windows IP address as server name and port is 1883  but MQTT thing is not connected with mosquitto ..
How can I connect mosquitto server and thingworx MQTT Thing.
(I'm using Mosquitto version= 2.1.1 and Thingworx 8.5)
Appreciate any suggestion
rjanardanAnswer
Ensure that you are using latest MQTT extension(2.1.2). You will also have to change Windows Firewall rules to allow communication on port 1883.
rjanardan16-PearlAnswer
Suraj26921-VisitorAuthor
I did not see any 2.1.2 extension on marketplace only available 2.1.1 version.
Yes I change Windows Firewall rules to allow communication on port 1883.
It is available in Support portal. Release 8.5 -> ThingWorx MQTT Extension
Support
Hi @Suraj2692.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
--Sharon
