How to connect MQTT server to thingworx?
I want to connect MQTT server to thingworx. I have download MQTT Broker in my system successfully. and Import MQTT extention in thingworx Successfully. Now i Want to Connect MQTT server to thingworx.
rjanardan16-PearlAnswer
Ru_0114-AlexandriteAuthor
I have taken an IP address in the server name, yet the thing is not connecting.
 I have taken systems's IP Address in serverName, Yet the thing is not connecting. Please check the attachment below.
What error do you see in Application logs when you save your MQTT thing?What is the version of MQTT extension? Are both TWX and broker on your local machine?
Support
Hi @Ru_01.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community.
--Sharon
