How to connect Printer, Router etc with Thingwrox.
Here I would like to know the standard secure method to connect agentless device like printer,Router, Switches etc in secure way. I know we can use SNMP protocol. But SNMP protocol is not secure. We also have SNMPv3 which is secure but we have many device which is on SNMPv1 and SNMPv2.
Please suggest.
22-Sapphire I
December 5, 2017
unfortunately if there isn't anything you can put on the device and you are dependent on what is provided, there is only so much that can be done.
If security is your concern, these type of issues will always exist.
Which means you'll have to connect snmp and then to the best of your abilities build validation and monitoring of activity after connection to ensure security
