How to control container size in runtime through an extension
Is it possible to control container size in runtime?
If so someone please guide me.
/VR
22-Sapphire I
Have you looked the Grow/Shrink ratios and grow/shrink max/min?
You can also set areas to be static if needed.
Velkumar19-TanzaniteAuthor
Hi @PaiChung
Thanks for your response.
I have checked these options but I'm still looking for a way to control programmatically ( examples: through extension).
/VR
22-Sapphire I
What is the use case that you need to control this programmatically?
Support
Hi @Velkumar.
Is the widget you're using custom?
--Sharon
HI @slangley
Yes
/VR
Support
Hi @Velkumar.
I'm not sure how to do what you need especially since you're using a custom widget.  Perhaps some of our developers in the community will have a suggestion
--Sharon
