How to convert date offset value(Number) to datetime format?
Hi
i need find yesterday date and  also i need to set hours also, but if i used sethours function datetime format automatically convert into number , if i apply function  setDate on offset value it will thourgh error?
here is code
var d = new Date();
var c =d.setHours(00,00,00,000);
var result =c.setDate(c.getDate() - 1);
i needto find yesterday date and  hours should be 00,00,00,000
That will be the code, but you must know that it will be done at Server Side TimeZone:
var result = new Date();
result = dateAddDays(result,-1);
result.setHours(0,0,0,0);
