May 14, 2020 9:32 AM UTC
How to count asset in thingworx license
I don't understand about asset in thingworx.
one asset mean one thing or one asset mean one device connect to thingworx or other
if one asset mean one thing when i create thing  by not connect device i will lost one asset right?
Please suggestion thank you
May 14, 2020 10:29 AM UTC
Definition of an Asset as described in PTC Software Products Licensing Basis.
“Asset” (designated as “IoT”) (also sometimes referred to in the product itself or elsewhere as a “Device” or a “Thing” or a “Remote Thing”) means a sensor, device, machine, system, web service, etc. that is modeled (represented) and/or registered as an asset (or “device” or “thing” within the Licensed Product) or any separately defined part of the foregoing if it is being treated as a separate asset within the software. For example, without limitation, an Asset could be a brake press, industrial dryer, another computer system, or a set of individual components within those machines if modeled or registered as a separate asset in the software), etc.
Nuttapol12-AmethystAuthor
May 14, 2020 2:52 PM UTC
Thank you for you suggession rjanardan.
I've read this manual before but i'm not sure.
OK I have another question.
if i need to know i have how many asset.
can i see number of asset from Licensing Subsystem Settings>twx_things right?
Such as i have SCP Premium Edition license will have twx_things limit = 50 yes or no?
May 14, 2020 3:25 PM UTC
Yes, you're correct. twx_things represents the limit.
