How to Create a Stored Procedure from thingworx service
I want to create a stored procedure from thingworx service, when I'm run test it throw an error
"Unable to Invoke Service ListServices on  TestDatabase: Incorrect syntax near 'GO'. "
for example:
USE [SERVICE1]
GO
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO
CREATE PROCEDURE [dbo].[ListServices]
@product_id nvarchar(32)
AS
BEGIN
END
supandeyAnswer
Hi @vxba could you try something like this :
Create procedure dbo.demoProc1
@Sno int
AS
SET NOCOUNT ON;
Select * from table1
where sNO = @Sno;
Let me know if there's any issue.
supandey5-Regular MemberAnswer
@Sno int
AS
SET NOCOUNT ON;
where sNO = @Sno;
vxba1-VisitorAuthor
Thank you! It worked for me
