How to create database in thingworx?
   How can I Create and Maintain Database (Tables with Relations) in Thingworx?
Surekha N.
slangleyAnswer
Support
Hi @Surekha.
Apologies for the misunderstanding.
It's not clear what your intent is but this link may be helpful.  Note there are several other links to resources that can help you determine the best architectural design for your environment.
Once you have reviewed this information, please let us know if you have further questions.  We will need to be provided with details of your requirements to provide appropriate answers.
--Sharon
If it's a simple database without relations, you can use out of the box DataTables objects.
Otherwise you will have to use the JDBC connector (http://support.ptc.com/help/thingworx_hc/thingworx_7_hc/#page/ThingWorx_Help_Center%2FThingWorxHelpCenterDITAFiles%2FThingWorxExtensibility%2FJDBCExtension%2FJDBCExtension.html%23) in order to connect to an external database and work with it.
Support
Hi @Surekha.
If the response provided by @CarlesColl answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
Surekha1-VisitorAuthor
Hi @slangley ,
I want to create relational database with in thingworx. But above mentioned is not that.
Surekha N.
