How to create feedback system to Build, deploy, test, and retrain a predictive machine learning mode
We have created data model using Thingworx. We want to improve the Accuracy of the data model by creating a feedback system in which data to be stored in database, retrieved and again send to retrain. Is there any possible way in which i can implement this?. Kindly reply to antony.joseph@maxbytetech.com. Any kind of help will be appreciated. Thank you.
Hello.
I am not aware of this sort of functionality being available in ThingWorx core. I am engaging with the ThingWorx Analytics specialists to see if that product might support adding this type of machine learning model to do what you ask.
Thank you,
-- Craig A.
vt-21-VisitorAuthor
Thank you
Antony,
Since Maxbyte is a current client of the ThingWorx Analytics Product, would you kindly open a case?
The question and guidance you seek is not something as straight forward as replying to the PTC Community Post.
Thanks & Regards,
Neel
22-Sapphire I
Thingworx could potentially help, this functionality isn't out of the box.
But if the data is available in some database, Thingworx can connect to that with JDBC
Thingworx can then repost that data to the model for retrain.
I am not familiar with exactly what services Analytics exposes, so I'm not sure what has to happen when the data gets to the analytics engine.
Pai,
All services are accessible via ThingWorx Services and APIs.
We would need more information, and discussion with Antony to better understand their use case, infrastructure, and frequency of stream, etc.
Neel
