How to create tree using code only without Tree entity?
Hi All,
ankiguptaAnswer
Hi Bhuwaneshwar Gupta​,
Change row.from = undefined;
row.from ="Root"
Root can be any value. We just need to add the same in the Tree widget -> RootParentId property.
I hope it helps.
As per my understanding tree widget is a nested infotable with Parent as String and child as infotable (  Datashape same as parent). So, you can try to code accordingly.
I hope it helps.
bgupta-210-MarbleAuthor
Hi Ankit,
Can you share me  some chunk of code for this?
Are you looking for the insert, delete functions in the Tree Infotable?
I don't have a sample code available for same.
Hi Ankit,
