How to delete NON editable users / undefined users via service ?
I was working on user creation script. few users has been created by non editable mode. I am able to see those users via GetAllEntities() not in composer,
Also, i found a way to see users in composer by creating one service to add users in particular usergroup after adding them I am able to see added(non editable) users in that usergroup.
In Usergroup if i click and delete user nothing happens,if I try to change property I get you can't delete non editable users.
Now I added 10+ undefined users in that group. Now, I need to remove the users from my instance.. I tried via deleteuser service but users are not deleted and still I am able to see them via GetAllEntities()...
Support
Hi @sabharees.
It sounds like something is missing from your script used for creating the users.  Can you provide that so we can take a better look?  Also, what version of ThingWorx are you running?
Have you checked the logs located at \ThingworxStorage\logs for clues?
--Sharon
sabharees15-MoonstoneAuthor
I am using .. ThingWorx 8.5.4,
yes, as you said I missed fieldvalues at the execution of the service but later I figured the cause of issue and corrected my code. Now, user creation is working fine but I am not able to delete previously created users(non editable).
