Apr 30, 2024 4:02 AM UTC
How to display Data in barchart
Hi Everyone,
I have a service which is fetching data and I have bind that service to grid widget which displays the data now I want to count each column unique data (I mean there are duplicates data in column) but I want them to count once and then showing that records to the Bar Chart graph and the graph data should change based on filter selected by user
for e.g. Suppose we have 4 column like, name , age , Class , place now I want to count each column and represent in bar chart
Thanks and Regards,
Lav
TonyZhangAnswer
Support
Dec 4, 2024 8:38 AM UTC
Hi @LY_10691079,
I guess what you are looking for is how to count distinct values of a column in infotable?
Check out below sample code.
let params = {
	t: infotableData /* INFOTABLE */,
	columns: columnName /* STRING */
// get distinct values of a column in the infotable first with below function
let distinct = Resources["InfoTableFunctions"].Distinct(params);
// count the number of distinct values using infortable.getRowCount function
let countDistinct = distinct.getRowCount();
Apr 30, 2024 4:44 PM UTC
Hello @LY_10691079 ,
Kindly follow the article having knowledge of implemeting the Bar Chart Graph in a Mashup:
https://www.ptc.com/en/support/article/CS351273?
Let m eknow if you have any further questions.
Regards
Bhawna
Community Moderator
May 8, 2024 4:48 AM UTC
Hello @LY_10691079,
It looks like you have a reply on your topic. If it helped you solve your question please mark the reply as the Accepted Solution.
Community Moderation Team.
TonyZhangCommunity ManagerAnswer
Support
Hi @LY_10691079,
let params = {
