How to display images in Repeater using Value Display widget ?
I have a File Repository Thing where it contains a folder with certain images in Storage.
I have to display the images in Repeater Widget.
It should contain 'n' number of columns as 'n' number of images a folder contains.
Is there any way to do?
Thanks for support !
AdamRAnswer
You would need to create a service to read the images from the repository, this would be done with the LoadImage service on the repository thing.  From there create an infotable that has a column of type image image and add each image to the infotable row.
Return this infotable from the service and bind it to a repeater that has the value display (and the mashup parameter of type image).  You can set the repeater "View" property to horizontal to get the images as columns.
Adam
AdamR14-AlexandriteAnswer
Adam
Maybe better, the exact same approach as Adam said, but instead of LoadImage (which will require a lot of memory to work) just get the FileRepository file Link (GetFileListingWithLinks) and use the Link to set the image with IMAGELINK instead of IMAGE.
Support
Hi @alekhya.
If one of the previous posts provided an answer to your question, please mark it as the Accepted Solution for the benefit of others who may have the same question.
--Sharon
