How to display notification in Mashup using WebSocket ?
I need to  implement a notification function.    When certain event get raised from ThingWorx and is captured by the subscription ,  the mashup will display a notification message .
Auto refresh widget may achieve this as a workaround ,  but I think WebSocket is  the best solution,  does ThingWorx provides OOTB function/extension for this kind of need ?
Regards
Sean
abjainAnswer
@seanccc : Please check this article which might be helpful in this case: https://www.ptc.com/en/support/article/CS269820
abjain15-MoonstoneAnswer
seanccc17-PeridotAuthor
@abjain ,
So,  it's still a "Pull"  solution ,  I need to call the service to get the alter information regularly from the Mashup using auto refresh widget.
Is there a "Push"  solution which can send message from ThingWorx server to Mashup ?
Sean
@seanccc : I think you will have to use auto-refresh widget for getting new values by calling services.
