@AP_9587236
You mean 10 field definitions in a DataShape? Default values of the field definitions remain unchanged when you add new filed definitions.
Yes. I can see the default values in datatable also. if the datatables rows added with new values, new values displaying in the datatable. Then once we removed those added values, the datatable rows should be filled with default values. But it is blank. Why ? If any filled columns datas removed in future, the cells should have default values instead of blank cells. What to do for that ?
@AP_9587236
What is the base type of the fields you are updating? I can see on my local instance that for numeric base type fields the default values are displayed after updating but for fields with string type the default values are not getting displayed.
