How to do Rest API Client Authentication Through Certficate in Thingworx Platform
My thingworx act as an client I need to get Data from third Party Server from REST API ( GET)  Using Certificate Based Client authentication, They given certificate Where do i save in Thingworx Platform
( Note : Am using Content Loader Function: Get Json Service)
supandeyAnswer
There is definitely documentation available, listing below some of them
-  Trust & Encryption - Hands On
-  ThingWorx setup SSL / HTTPS on Tomcat with Self-Signed Certificate
-  Configuring ThingWorx / Tomcat for SSL using a Signed Certificate from a Certificate Authority (CA)
-- Edit -- (Sorry missed to add this )
Above resources should help you get SSL enabled for Tomcat, it includes the step on how to setup the keystore which will be used by Tomcat. And my understanding is that you will need HTTPS enabled for Tomcat to make it a secure connection.
Hi @sarathi is  you Tomcat running ThingWorx configured with SSL? If so could you test by installing this certificate in the keystore used by the Tomcat ?
sarathi1-VisitorAuthor
Hi @supandey  no i configured thingworx server in http port only , is there mandatory to configure tomcat to https port in order to do  certificate based client authentication ,
  If so how to store certificate in keystore used by  Tomcat, is there any document available?
supandey5-Regular MemberAnswer
